16 years agoProgram runs in loop
I have written a program that writes to the user through nios 2 console (jtag uart) and takes user input as well. However, the program does not pause to accept user input. Instead it continues to run...
16 years agoAhhh, if you're using the small C library, you're going to have to get trickier.
If I remember right, you may may be able to use the regular "read()" function which I think will block. You may also want to access the UART driver directly ...data = IORD_ALTERA_AVALON_JTAG_UART_DATA(JTAG_UART_0_BASE);
if(data & ALTERA_AVALON_JTAG_UART_DATA_RVALID_MSK){
// If you're here you've got data to read.
data = data & ALTERA_AVALON_JTAG_UART_DATA_DATA_MSK;
}else{
// No data try again
} Jake
