21 years agoprogram run error!
when I run a program (hello_world.c)in niosII IDE, some errors occured .what's wrong?
Error! : Unable to load memory block at address 0x800020 from ELF file Debug/hello_world_4.elf Fatal Error! : Memory map is not consistent with memory image file - check that file 'Debug/hello_world_4.elf' is compiled and linked for system 'D:\test\lab5\my_cpu.ptf'3 Replies
Hi,skybird.
what hardware image did you use?your own or the example. If is your own ,did you generate it successfully in sopc builder? I think the problem is address . The above is just personnel viewpoint. - Altera_Forum
Hi,zzh! Thank you for your answer!
The development board I used is Stratix GX ep1s40f1020c5. The nios system which is my own can generate successfully in sopc builder . - Altera_Forum
Hi skybird,
<div class='quotetop'>QUOTE </div> --- Quote Start --- Fatal Error! : Memory map is not consistent with memory image file - check that file 'Debug/hello_world_4.elf' is compiled and linked for system 'D:\test\lab5\my_cpu.ptf'[/b] --- Quote End --- from this message, I think that your software project it's not correctly linked with your hardware configuration: I mean, when u have created your project have you specified the file "my_cpu.ptf" and created an associated system library?...or have u downloaded the correct hardware configuration to FPGA, before downloading software project? bye
