19 years agoProgram Flash with NIOS II Project
We're back with another issue. There could be a simple solution to this since this is our first project using Quartus/SOPC Builder/Nios II. Regardless, our problem is as follows: We have ...
19 years agoPROBLEM SOLVED!
Nevermind the previous post. The Flash memory WAS getting programmed however in a previous tutorial we ran through it had us change options in the project system library. We never returned these to default after the tutorial. Once we returned the settings to default in the project system library properties BINGO. Thanks for all your input thus far slacker! IF anyone knows a good source to get information on a c/c++ vga controller that would help out alot. This board will be controlling a 640x480 LCD touchscreen display. Would rather write the code in C than VHDL. THANKS!
