19 years agoProgram Flash with NIOS II Project
We're back with another issue. There could be a simple solution to this since this is our first project using Quartus/SOPC Builder/Nios II. Regardless, our problem is as follows: We have ...
19 years agoOk we created the Objdump file and have the first chunk of the file posted below. The first thing that caught our eye is a lot of the files that seem to be included ".rodata ect. ect." appear to say they are of size 000000. Should they be zero or should they actually be something? Let me know if you need anymore of the objdump file posted. Thanks!
Also, is it a problem that the start address is said to be 0x00400000 when our flash memory size is 0x003fffff? Media_Center_X.elf: file format elf32-littlenios2 Media_Center_X.elf architecture: nios2, flags 0x00000112: EXEC_P, HAS_SYMS, D_PAGED start address 0x00400000 Program Header: LOAD off 0x00000094 vaddr 0x00000000 paddr 0x00000000 align 2**0 filesz 0x00000000 memsz 0x00000000 flags r-x LOAD off 0x00000094 vaddr 0x00400000 paddr 0x00400000 align 2**0 filesz 0x000000b0 memsz 0x000000b0 flags r-x LOAD off 0x00000144 vaddr 0x00800020 paddr 0x00800020 align 2**0 filesz 0x00000000 memsz 0x00000000 flags rw- Sections: Idx Name Size VMA LMA File off Algn 0 .entry 00000000 00000000 00000000 00000094 2**5 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .exceptions 00000000 00800020 00800020 00000144 2**0 CONTENTS 2 .text 000000b0 00400000 00400000 00000094 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 3 .rodata 00000000 004000b0 004000b0 00000144 2**0 CONTENTS 4 .rwdata 00000000 00800020 00800020 00000144 2**0 CONTENTS, ALLOC, LOAD, DATA 5 .bss 00000000 00800020 00800020 00000144 2**0 ALLOC 6 .sdram_0 00000000 00800020 00800020 00000144 2**0 CONTENTS 7 .epcs_controller 00000000 00480800 00480800 00000144 2**0 CONTENTS 8 .sram_0 00000000 004000b0 004000b0 00000144 2**0 CONTENTS 9 .cfi_flash_0 00000000 00000020 00000020 00000144 2**0 CONTENTS 10 .comment 0000002c 00000000 00000000 00000144 2**0 CONTENTS, READONLY 11 .debug_aranges 00000040 00000000 00000000 00000170 2**3 CONTENTS, READONLY, DEBUGGING 12 .debug_pubnames 0000001f 00000000 00000000 000001b0 2**0 CONTENTS, READONLY, DEBUGGING 13 .debug_info 0000016c 00000000 00000000 000001cf 2**0 CONTENTS, READONLY, DEBUGGING 14 .debug_abbrev 0000007a 00000000 00000000 0000033b 2**0 CONTENTS, READONLY, DEBUGGING 15 .debug_line 00000175 00000000 00000000 000003b5 2**0 CONTENTS, READONLY, DEBUGGING 16 .debug_frame 00000028 00000000 00000000 0000052c 2**2 CONTENTS, READONLY, DEBUGGING 17 .debug_str 000000dc 00000000 00000000 00000554 2**0 CONTENTS, READONLY, DEBUGGING 18 .debug_alt_sim_info 00000020 00000000 00000000 00000630 2**2 CONTENTS, READONLY, DEBUGGING
