16 years ago
Program EPCS with 2 Nios II Images
I have 2 Nios II with 2 individual RAM. These 2 RAMs stored the same program code. Can I program only one code into EPCS using Nios II FLASH PROGRAMMER and boot the 2 Nios II from their respective RAM to execute the same program?
Caridee
    Hi Jake and Eddis,
    Thanks for replies.
    Other than remote_update component in my sopc, do I need a Nios II processor to control the remote configuration? I ask so because my hardware image does not contain processor...
    Actually you do not need NIOS, but it is easer to use it.. You can put remote update as block in schematic diagram using MegaWizard PlugIn Manager. .. and initiate reconfigure , write address and etc. by hardware.. for me personally simpler and faster is to use NIOS processor.
    Any way you need read PDF about remote_update first and than ask questions.. because most of your question can be answerred by reading components describtions..
