16 years agoProgram EPCS with 2 Nios II Images
Hello, I have 2 Nios II with 2 individual RAM. These 2 RAMs stored the same program code. Can I program only one code into EPCS using Nios II FLASH PROGRAMMER and boot the 2 Nios II from their ...
16 years agoSo it sounds like you are using Active Parallel programming with a CFI flash and the cyclone III. If this is the case, then eddis is correct, the remote_update core is what you'll need to dynamically load the desired FPGA image.
Jake
