16 years agoProgram EPCS with 2 Nios II Images
Hello, I have 2 Nios II with 2 individual RAM. These 2 RAMs stored the same program code. Can I program only one code into EPCS using Nios II FLASH PROGRAMMER and boot the 2 Nios II from their ...
16 years agoHi Jake or Daxiwen,
thanks for the response. What if i have 2 .sof files to be programmed into a CFI flash memory? Can I program these 2 .sof files into the flash memory and configure the FPGA with these 2 sof files separately through switch button? Thanks for your answer.
