20 years agoProgram EPCS from user code?
I'd like to add a firmware upgrade capability to my NIOS system. Since the end user won't have a development system with JTAG I'd like to add a way of reprogramming the EPCS with FPGA con...
20 years ago --- Quote Start --- originally posted by slacker@Jul 13 2006, 04:08 PM if you've ever programmed the sof to flash, you should see a <sof_name>.flash file in the debug|release subdirectory of your project. there's also an auto-generated <project_name>_programmer.sh script which should make it apparent how all this stuff works....
this script uses:
1. sof2flash to generate the <sof_name>.flash file.
and
2. nios2-flash-programmer to program it to the flash device.
cheers,
- slacker
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16880)
--- quote end ---
--- Quote End --- Ahh, thanks, that explains it. I work on two machines, Windows for Quartus and Linux for NIOS IDE and I was looking on the Linux box which wasn't used to program the sof to flash. So it looks like reading SREC or .flash is the most convenient file format to use for a in-system ugrade utility.
