20 years agoProgram entry point
hello we are using nios ii 5.1. we are had create a custom bootloader for remote firmware updates via custom interface (no jtag cable will be available on fw update process). previosly, in nios...
20 years ago> I would probably just leave all the automated stuff alone and add a small
> assembly module .... Actually, I take that back 8-P ... you can achieve the same by simply adding ALT_NO_BOOTLOADER to your system library compiler preprocessor defs. Then when you use objcopy to create the binary, just adjust the .entry section VMA. Regards, --Scott
