13 years agoProfiling tools for uClinux
I realized that gprof does not work with uClinux, unfortunately. Nevertheless, oprofile is an another solution and I tryed to install it. But, I have problems with system's generation:checking for dlopen in -ldl... yes
checking for main in -lintl... no
checking for bfd_openr in -lbfd... no
configure: error: bfd library not found
make: *** Error 1
make: Leaving directory `/home/carlos/uclinux/uClinux-dist/user/oprofile'
make: *** Error 2
make: Leaving directory `/home/carlos/uclinux/uClinux-dist/user'
make: *** Error 2
make: *** Error 1
I follow tutorial http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:oprofile The bfd library issue is a problem very known with oprofile and I don't found any solution. Please can you help me? Regards!No RepliesBe the first to reply
