21 years agoProduction line board test
Once you get your Nios design into production, what kind of setup do you use for configuration and test? It seems unrealistic to expect each test station to have a full Quartus install, even if...
21 years agoHi Mike,
I suppose it depends on your system. If you are using EPCS serial flash, it may be possible to get away with using only the (free) Quartus standalone programmer. I think this is just a free Altera download.. if any license is required there should be no cost (send in a nic or hard drive ID and get a license file by email, if anything). The procedure is to (on a computer with all of the dev tools installed) roll up the fpga .sof file and software .srec file into a single file that the programmer can use in a production line situation... I recently helped out a customer (added some conversion functionality into nios-convert) that went into 1.1 for this purpose, which converted our .srec into i-hex that the quartus convert programming files utility uses to combine data into a single programming file. Since it requires several steps to perform it is not a highlighted feature though. If you are using parallel flash and aren't programming flash in some conventional programmer before soldering onto the board, then your idea bout using the command-line nios2-flash-programmer tool is a good one. This will still require installation of quartus + nios to get all the tools in place, but you can feel free to experiment with the flash programmer java executables if you'd like in order to run in a more standalone mode (quite honestly I don't know if this will work -- but it sounds like its worth a try)... even if that does not work, I don't see any reason why you should need a license file for it to operate as command line tools such as the flash programmer aren't doing things like HW compilation or generation, which do use the license files http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
