21 years agoProduction line board test
Once you get your Nios design into production, what kind of setup do you use for configuration and test? It seems unrealistic to expect each test station to have a full Quartus install, even if...
21 years ago.... additional question:
can I perhaps install CYGWIN on a separate windows machine and use the perl-script generated by flash-programmer (xxx.sh) together with the NIOS tools 'sof2flash' , 'elf2flash' and 'nios2-flash-programmer' to have a stand-alone solution ? Mike p.s. CYGWIN is free and is a Linux-like environment for Windows (www.cygwin.com)
