20 years agoProcessor paused, no errors
I'm seeing the "leaving processor paused" message however there are no errors. "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID...
19 years agoin main tab:
the check button "validate nios ii system id before software download" is unchecked and disabled (i can´t click it) -- in target connection tab: jtag cable selected is USB-Blaster jtag device is 1 EP2S180 and... "nios ii terminal comunication device": none <do not launch NIOS II Terminal> and there´s no other option "host com port" is disabled -- in common tab: type of lauch configuration set to Local launch in background disabled That´s all i guess Thanks Gabriel
