20 years agoProcessor paused, no errors
I'm seeing the "leaving processor paused" message however there are no errors. "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID...
19 years agohi!
i had the same problem. maybe i can help you out! in my case the verification didn't work. and i had the same console output. so try this steps: goto menu -> Run ->Run... (it's the run setup) on the main page uncheck "Validate Nios II system ID before software download" click apply, run greetz Andreas
