20 years agoProcessor paused, no errors
I'm seeing the "leaving processor paused" message however there are no errors. "Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: OK Reading System ID...
19 years ago --- Quote Start --- originally posted by jamesw2@Sep 19 2006, 08:47 AM i'm seeing the "leaving processor paused" message however there are no errors.
"using cable "usb-blaster [usb-0]", device 1, instance 0x00
pausing target processor: ok
reading system id at address 0x008508b8: verified
initializing cpu cache (if present)
ok
downloading 01000020 ( 0%)
downloading 01010000 (83%)
downloaded 77kb in 1.2s (64.1kb/s)
verifying 01000020 ( 0%)
verifying 01010000 (83%)
verified ok
leaving target processor paused"
i see this quite regularly and have asked altera about it but there has been limited help. one possible problem is that the pll hasn't locked, but i've brought the signal out to a pin and it is showing locked (high).
i'm using nios ii v6.0 build 93 on a stratix development board (ep1s10). the fpga image is loaded onto the board. i'm also using the logic analyzer but everything looks ok there too.
any ideas why the processor would be paused when there are no errors?
thanks in advance for the insight.
james.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18354)
--- quote end ---
--- Quote End --- What setting do you have in IDE Run/Debug Lauch target? There is a setting that will cause the IDE to download, but not run the software. Cheers, - slacker
