20 years agoProcessor not responding
I have the Cyclone II DSP Development Kit (2C35 device) but cannot get my "hello world" program to run. I always get the following message.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: FAILED Leaving target processor paused I have carefully followed the steps outlined in the Nios II Development Kit Getting Started User Guide and everything works as expected, right up to the part that says "Click Run..." on page 1-14. I've seen other postings with similar problems but I haven't seen resolution. If I've missed something, please point me to the answers, posts, documentation, whatever. Is this a known problem? Is it possible that my "Nios II Device Drivers" project in the IDE is bad, causing this problem, because of earlier mistakes on my part? How can I recreate "Nios II Device Drivers"? Looking for any suggestions or ideas.11 Replies
--- Quote Start --- originally posted by zly_1207@Mar 12 2007, 02:50 AM using cable "nios ii evaluation board [usb-0]", device 1, instance 0x00pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22211)
--- quote end ---
--- Quote End --- Hi all, i also have this often re-occuring problem, could you please help me? Thank you in advance. I have followed the example you may find in tt_nios2_hardware_tutorial.pdf (altera website.) Everything goes fine to the point where I need to upload the program... Then I get the error which I have mentioned above. what could have gone wrong? I use nios II IDE 7.0 and quartus II 7.0 for the DE2 (EP35) education board. (with one usb cable) * I only use the free license. > Could this be causing the problem? * In the tutorial I have read the following: "You must have an Altera USB-Blaster download cable, revision B or higher." > How can I check if this is the problem? I also have following questions: - is there anybody who has succesfully completed the example? (on the DE2/EP35 education board, with free license) - are there other causes for my problem? once again thank you in advance. Some additional info: I can create a simple NIOS II core in hardware on which I can upload a simple program with the "Altera Debug Client". For more complex programs I however would like to use the NIOS II IDE --- Quote Start --- originally posted by slash@Jun 15 2006, 09:52 PM run your programm in simulator, is it work?
make sure that you have usb-blaster [usb-0] only in jtagserver!
it help me in solving the same problem=) good luck!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16203)
--- quote end ---
--- Quote End --- Could you please tell me how I can check this?
