20 years agoProcessor not responding
I have the Cyclone II DSP Development Kit (2C35 device) but cannot get my "hello world" program to run. I always get the following message. Using cable "USB-Blaster [USB-0]", device 1, instanc...
19 years ago --- Quote Start --- originally posted by zly_1207@Mar 12 2007, 02:50 AM using cable "nios ii evaluation board [usb-0]", device 1, instance 0x00
pausing target processor: not responding.
resetting and trying again: failed
leaving target processor paused
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=22211)
--- quote end ---
--- Quote End --- Hi all, i also have this often re-occuring problem, could you please help me? Thank you in advance. I have followed the example you may find in tt_nios2_hardware_tutorial.pdf (altera website.) Everything goes fine to the point where I need to upload the program... Then I get the error which I have mentioned above. what could have gone wrong? I use nios II IDE 7.0 and quartus II 7.0 for the DE2 (EP35) education board. (with one usb cable) * I only use the free license. > Could this be causing the problem? * In the tutorial I have read the following: "You must have an Altera USB-Blaster download cable, revision B or higher." > How can I check if this is the problem? I also have following questions: - is there anybody who has succesfully completed the example? (on the DE2/EP35 education board, with free license) - are there other causes for my problem? once again thank you in advance. Some additional info: I can create a simple NIOS II core in hardware on which I can upload a simple program with the "Altera Debug Client". For more complex programs I however would like to use the NIOS II IDE --- Quote Start --- originally posted by slash@Jun 15 2006, 09:52 PM run your programm in simulator, is it work?
make sure that you have usb-blaster [usb-0] only in jtagserver!
it help me in solving the same problem=) good luck!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16203)
--- quote end ---
--- Quote End --- Could you please tell me how I can check this?
