20 years agoProcessor not responding
I have the Cyclone II DSP Development Kit (2C35 device) but cannot get my "hello world" program to run. I always get the following message. Using cable "USB-Blaster [USB-0]", device 1, instanc...
20 years ago --- Quote Start --- originally posted by davew@Jun 15 2006, 04:25 PM thanks, avishay, for the suggestion. i checked the unassigned pins and they are already set to tri-state input, so i looked for other possible problems.
i noticed something else that is probably causing my problem - now i need help to resolve it. in sopc builder, i'm using the standard reference design but i have an error and a warning at the bottom message window of the gui.
the error says "one or more components could not be located (ddr_sdram_component). check Search Path[/b] under file->sopc builder setup... menu." I tried adding some directories like it said, but that doesn't seem to help. Next to the ddr_sdram component in the active components window, it says "(NOT INSTALLED)". Do I need to reinstall Quartus? How can I install just the missing component? (Where do I find it?) The warning says "nios development board, cyclone ii edition: SSRAM data byte-lanes are swapped. Refer to the Nios Development Board, Cyclone II Edition Reference Manual." Is this normal for this board? Do I need to correct this? Dave <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16190) --- Quote End --- [/b] --- Quote End --- Hello. Maybe you need to install the Megacore IP library CD.
