16 years agoProcess for Embedding NIOS Code in .pof
I am having a problem getting my NIOS code to load into my configuration device. i believe the real question here is how do i get the onchip_memory.hex file generated when i compile the nios c...
16 years agoIt might be worth looking at the elf program that is generated to check that the code and data sections have the correct addresses for the internal memory blocks. The link script used by the IDE build rather assumes that your code+data is being loaded into a large memory area (eg the SDRAM) and code is added to copy the data into internal memory.
Look at the output of 'objdump -p' (and maybe 'objdump -h') to ensure that the physical and logical addresses are the one you need.
