16 years agoProcess for Embedding NIOS Code in .pof
I am having a problem getting my NIOS code to load into my configuration device. i believe the real question here is how do i get the onchip_memory.hex file generated when i compile the nios c...
16 years agoWhat version of the tools are you using?
You have to open the "Run Configuration" dialog for the software project you are working with. From the IDE: Run->Debug... Then click on the debugger tab. There is a panel entitled "Download and Reset". Under this panel, change the selection from "Download program to RAM" to "Attach to existing program on target (no download)." Jake
