16 years agoproblems with timer interrupts with nios II/f
Dear all, I've been using uclinux with an altera project using NIOSII/s cpu. In this project I've used the standard ram, timer, uart, ethernet, etc.. plus a timer called high_res_timer with 1 mse...
16 years agoOne potential gotcha when going from NIOS II/s to /f is the addition of the data cache. Make sure that writes to the timer registers (or other hardware) bypass the data cache or you will have problems.
