16 years agoproblems with the global pointer
Hello! I have a project with three memories, one sram, one sram with back up and an On-Chip Memory. I'm using Interniche stack, superloop mode. When all code sections goes in th SRAMs, the...
16 years agoYou can force a data item into (or out of) the 'small data' areas - accessed though %gp - using gcc __attribute__((section("name"))).
Data in sections .sdata, .sdata.*, .sbss, .sbss.* etc is accessed through %gp. The linker script defines how the sections are actually mapped into memory. You'll probably need to edit the one the IDE uses. There is also a bug (well missing optimisation) in gcc so it fails to uses %gprel(symbol+offset)(gp) when accessing structures that have been placed in the 'small data' area.
