20 years agoproblems with programing flash
hi, I have an altera cyclone evalution board (1c12) and I want to program the flash but i fail.... <div class='quotetop'>QUOTE </div> --- Quote Start --- [SOPC Builder]$ nios2-flash-progr...
20 years agohi, I just have an other question about flash programmer.
when I try to my flash with the project, I have this error : <div class='quotetop'>QUOTE </div> --- Quote Start --- [SOPC Builder]$ nios2-flash-programmer --epcs --base=0x0 epcs_controller.flash --sof=../../../../components/altera_nios_eva l_board_cyclone_1c12/system/altera_nios_eval_board_cyclone_1c12.sof --verbose 7 juin 2006 11:23:20 - (FIN) nios2-flash-programmer: nios2-flash-programmer starting 7 juin 2006 11:23:21 - (INFO) nios2-flash-programmer: args = --epcs --base=0x0 epcs_controller.flash --sof=../../../../compo nents/altera_nios_eval_board_cyclone_1c12/system/altera_nios_eval_board_cyclone_1c12.sof --verbose 7 juin 2006 11:23:21 - (INFO) nios2-flash-programmer: Attempting to read input-data from epcs_controller.flash 7 juin 2006 11:23:23 - (INFO) nios2-flash-programmer: Launching Quartus Programmer to download: ../../../../components/altera_nios_eval_board_cyclone_1c12/system/altera_nios_eval_board_cyclone_1c12.sof 7 juin 2006 11:23:23 - (FIN) nios2-flash-programmer: Quartus Pgm launched Info: ******************************************************************* Info: Running Quartus II Programmer Info: Command: quartus_pgm --no_banner --mode=jtag --operation=p;../../../../components/altera_nios_eval_board_cyclone_1c12/ system/altera_nios_eval_board_cyclone_1c12.sof Info: Using programming cable "Nios II Evaluation Board [USB-0]" Info: Started Programmer operation at Wed Jun 07 11:23:27 2006 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x020830DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Wed Jun 07 11:23:31 2006 Info: Quartus II Programmer was successful. 0 errors, 0 warnings Info: Processing ended: Wed Jun 07 11:23:31 2006 Info: Elapsed time: 00:00:07 7 juin 2006 11:23:31 - (FIN) nios2-flash-programmer: SOF programming done. exit code = 0x0000 Connecting with target design Attempting to resynch with target Attempting to open flash device 7 juin 2006 11:23:37 - (INFO) nios2-flash-programmer: Extracting data for: FlashDevice at: 0x00000000 7 juin 2006 11:23:38 - (GRAVE) nios2-flash-programmer: Flash file is too large to fit in flash memory[/b] --- Quote End --- But my .flash file is only 2 474 Ko. I use an 1c12 eval board. Do you now how to fix the problem ?
