21 years agoProblems with program_flash utility, or is it?
Greetings, I downloaded ecos just recently. I have gone through the "getting started" documentation and I have run into problems. Here's my situation (note that I have used the standard example ...
21 years agoThe program_flash script assumes that you only have a single cable connected. If you want to use an alternative cable, i.e. use the --cable option, then you will need to edit the program_flash script and add the option to the call to nios2-flash-programmer (if you do this, you'll obviously need to save the script under a different name to avoid having it overwritten).
