15 years agoProblems with Nios II
Hi all I'm new in using nios II and I have some problems: after generating system on SOPC Builder with: - nios 2/f - jtag uart - pio (output, 1 bit) - sysid - onchip_memory ...
15 years ago --- Quote Start --- - to implement a bigger on chip memory i have to set a higher number of bytes or select a different one? --- Quote End --- Right. Set a bigger size in sopc builder, changing onchip mem properties. Regarding the other issue, using main is correct. Probably you have some something wrong in linker script. I still use Quartus 9 and Nios IDE, so I can't help you much with Quartus 10 and Nios SBT
