15 years agoProblems with Nios II
Hi all I'm new in using nios II and I have some problems: after generating system on SOPC Builder with: - nios 2/f - jtag uart - pio (output, 1 bit) - sysid - onchip_memory ...
15 years agoThe first problem seems due to the fact the initial code didn't fit into onchip_memory. Enabling small C lib and reduced drivers generates a code with smaller footprint. If you need the complete lib and drivers you may try to implement a bigger onchip mem, provided your device has it.
The second problem probably indicates that thelinker can't find the main() entry point. Does your project use main or alt_main? Last remark: you wrote "altera_avalon_poi_regs.h"; is this a mistype or is really like this in your code? It should be altera_avalon_pio_regs.h Regards
