20 years agoProblems with NIOS IDE's Flash Programmer.
Hi friends, I'm using NIOS II 5.01 with ep1s20+epc8+am29v065+2*idt71v416, now the off-chip sram and nor-flash can pass the test with memtest sample application code. But when I built a...
20 years agoWhat's your CPU's exception handler's address?
And is this while you're building the mk_target_board project? Because you shouldn't be adding any code to that project...
