15 years agoProblems with my own Drivers
Hello, I have write my own Avalon Slave Component and would like integrate the driver in my Eclipse projekt... I have a the problem that the driver would not integrated automatic in the B...
15 years agoIf you use the Altera nios2-bsp script with the --debug option, you should see lots of output related to finding locating system ip modules and finding the best driver match.
1. Make sure the search path to your _sw.tcl file is present at the beginning of the debug output. If your IP is located in a standard location such as the quartus project folder, then you are ok. 2. Search for your discovered module in the debug output. You should see the attemp to match a driver to your module. You should see your driver and a reason as to why it was not considered compatible (skipped over)
