19 years agoproblems with makefile
I have installed the new Versions (6.1) of Quartus and the NIOS tools. Now when I build my project the build process is abborted wit the error message: " /gnu_rules.mk:240: *** multiple target patterns." Parts of the source code are used by different projects and so I use a linked folder for this code. If I don't use linked Folders (copy the code into the project folder)then the project will be build without an error. Is there a solution without copying the files to the project folders? Regards. JoachimNo RepliesBe the first to reply
