21 years agoproblems with iCACHE!
Hi! I've been working with the nios/e , and I have a program now working and tested. It uses threads (eCos) and interrupts (three). the fact is that if ONLY change the Nios2/e to Nio...
21 years agoWhen using a "ROMRAM" configuration, eCos uses the standard Altera bootloader to load code from flash to RAM. The source for this is in the Nios II kit in the directory:
components\altera_nios2\sdk\src\boot_loader_sources
