20 years agoproblems with Flash by redboot on eCos with NIOS2
Hello, I tryed to make reboot working for StratixII Board with NIOSII Processor. Redboot permanently failed on detecting the flash device correctly. As it turns out, the flash detection ro...
20 years agoHi Marek,
I think I had the same problem as you today when I was using my AM29LV128 flash. The device ID made no sense. I found that the code which reads the device ID was assuming that the flash was connected in 16 bit mode. I followed the suggestion in this post: http://forum.niosforum.com/forum/lofiversi....php/t1841.html (http://forum.niosforum.com/forum/lofiversion/index.php/t1841.html) and this fixed my problem. The flash ID was then read as 01:7E:12:0 as it should be. Mike
