20 years agoproblems with Flash by redboot on eCos with NIOS2
Hello, I tryed to make reboot working for StratixII Board with NIOSII Processor. Redboot permanently failed on detecting the flash device correctly. As it turns out, the flash detection ro...
20 years agoHi Marek,
> Does anyone knows a solution to tell the compiler to automatically convert volatile > pointer memory instructions to correct ldio/stio instructions? There is none :-( -- the volatile keyword has nothing to do with cache. It _may_ however, affect optimizations with respect to memory access (cache or no-cache). > Any solutions? The quick 'n dirty is to use cache bypass (set bit 31 of the address). The "purist" way is a rewrite. Unfortunately, you may find a rewrite is like peeling an onion -- it seems like there's always another module that needs a re-write. Regards, --Scott
