20 years agoproblems with flash and tri-state-bus
Hi everybody,
on a custom board, I use a tri-state-bus and cfi flash component to connect an amd compatible flash device with a 16 bit wide bus. The entrypoint to my application is alt_main, no HAL drivers or interrupts are initialized. I am just using macros from io.h to access the flash. # define AUTO_SELECT() { (IOWR_16DIRECT((flash_base), 0xAAA, (ushort)0xAA)); (IOWR_16DIRECT((flash_base), 0x555, (ushort)0x55)); (IOWR_16DIRECT((flash_base), 0xAAA, (ushort)0x90)); } # define CFI_QUERY() (IOWR_16DIRECT((flash_base), 0xAA, (ushort)0x98)) # define READ_RESET() (IOWR_16DIRECT((flash_base), 0xAAA, (ushort)0xF0)) # define READ_DIRECT(src, offset) (IORD_16DIRECT(src, (ushort)offset)) int main (void) __attribute__ ((weak, alias ("alt_main"))); int alt_main(void) { unsigned char *flash_base; int val[10]; flash_base = (unsigned char *) EXT_FLASH_BASE; while(1) { usleep(5000000); CFI_QUERY(); val[0] = READ_DIRECT(flash_base, 0x20); val[1] = READ_DIRECT(flash_base, 0x22); val[2] = READ_DIRECT(flash_base, 0x24); READ_RESET(); AUTO_SELECT(); val[3] = READ_DIRECT(flash_base, 0x00); val[4] = READ_DIRECT(flash_base, 0x01); READ_RESET(); } } The application just reads a few values from the CFI table and the manufacture and device ids. I am using signal tap to monitor the adress, data, read, write and select pins. Well, signal tap shows mor accesses to flash than the system should perform! After CFI_QUERY() I can see 6 read cycles wehre only 3 should take place. The first to read cycles are doubled and and the last one reads from offset 0x26 (my last read incremented by 2). In AUTO_SELECT() there is an additional write cycle to the address of my last cycle incremented by 2. Does anybody know where the additional read and write cycles come from??? --wolfgang1 Reply
Ok, the problems seems to be related to the avalon bus.
As I understand, the additional read cycles are related to the dynamic addressing and are ok, because the additional data is discarded by the bus. The additional write cycle indeed is a problem. As far as I could figure out, it occurs only writing to an odd address. I do not know if this is mentioned in any documentation, at least I could not find it. But it is known for sure, that I know after having a closer look to the HAL cfi flash driver and the development board schematics. Have fun, --Wolfgang
