20 years agoproblems with flash and tri-state-bus
Hi everybody, on a custom board, I use a tri-state-bus and cfi flash component to connect an amd compatible flash device with a 16 bit wide bus. The entrypoint to my application is alt_main, ...
20 years agoOk, the problems seems to be related to the avalon bus.
As I understand, the additional read cycles are related to the dynamic addressing and are ok, because the additional data is discarded by the bus. The additional write cycle indeed is a problem. As far as I could figure out, it occurs only writing to an odd address. I do not know if this is mentioned in any documentation, at least I could not find it. But it is known for sure, that I know after having a closer look to the HAL cfi flash driver and the development board schematics. Have fun, --Wolfgang
