15 years agoproblems with debug Nios
I have created the project in SOPC Nios + onchip_ram + jtag_uart + two pio_led + external IRQ + timer + pll + C code. This project with Nios works, all OK. Debug in the IDE works too. After that I in...
15 years ago --- Quote Start --- could it be that the new added logic just produced more noise and disturbs the jtag ? with added logic the jtag fails without it works ? --- Quote End --- I have solved the problem. MSchmitt, You are right. After the analysis of jtag signals on pcb, I found a signal which influences on TCK. After I have disconnected him from altera, debug jtag for nios began to work. Thanks all for the help.
