15 years agoproblems with debug Nios
I have created the project in SOPC Nios + onchip_ram + jtag_uart + two pio_led + external IRQ + timer + pll + C code. This project with Nios works, all OK. Debug in the IDE works too. After that I in...
15 years agoYou should check the hold requirements too. Do you use Timequest or the classical timing analyser?
The timing settings for the debug uart are setup automatically, as long as you give the system clock frequency. Do you have all the licenses or are you in Opencore evaluation mode? In the latter case, be careful not to close the small Opencore alert box, it would make the licensed part stop.
