15 years agoproblems with debug Nios
I have created the project in SOPC Nios + onchip_ram + jtag_uart + two pio_led + external IRQ + timer + pll + C code. This project with Nios works, all OK. Debug in the IDE works too. After that I in...
15 years ago --- Quote Start --- my design hasnot special timing constraints. --- Quote End --- Almost every design has timing constraints. You must constrain your design to be sure that it can run at the frequency you use.
