15 years agoProblems with DE1 board and MicroC/OS-II RTOS
Hi, I'm having some problems because I want to implement an operating system, the MicroC/OS-II, on the DE1 board. First, I followed the tutorial "Introduction to the SOPC Builder" on Altera's s...
15 years agoIn SOPC builder, you'll find the timer in the library: Peripherals > Microcontroller Peripherals > Interval timer
Set a timeout period of 10 ms and select the Simple periodic interrupt preset. Then regenerate your SOPC system and recompile Quartus project. I don't remember if the bsp settings are automatically adjusted. If not you may need to update them and select the timer you just created as system timer before recompiling the software.
