13 years agoProblems with Cyclone IV and DP83848C
Dear all, I've made my own board of Cyclone IV EP4CGX110CF23C7. And i want to make a ethernet module with DP83848C which is surpported by the TSE core. However, when i have completed my SOPC syst...
13 years ago --- Quote Start --- The extra signals in Signaltap are in red, which indicates that they don't exist. Are you sure you picked them from the TSE and not the top level? --- Quote End --- Okey, please find fixed signal_tap output below. I suppose the TSE completely ignore the receivement... Just for notice I run the NIOS code before I caught the data in the signaltap: https://www.alteraforum.com/forum/attachment.php?attachmentid=7806 To remind the console output of the NIOS build is here:
InterNiche Portable TCP/IP, v3.1
Copyright 1996-2008 by InterNiche Technologies. All rights reserved.
prep_tse_mac 0
Can't read the MAC address from your board. We will assign you
a MAC address.
Please enter your 9-digit serial number. This is printed on a
label under your Nios dev. board. The first 3 digits of the
label are ASJ and the serial number follows this.
-->Created "Inet main" task (Prio: 2)
Created "clock tick" task (Prio: 3)
123456789
123456789
Your Ethernet MAC address is 00:07:ed:ff:cd:15
Static IP Address is 192.168.0.180
prepped 1 interface, initializing...
INFO : TSE MAC 0 found at address 0x10001000
INFO : PHY National DP83848C found at PHY address 0x01 of MAC Group
INFO : PHY - Automatically mapped to tse_mac_device
INFO : PHY - Restart Auto-Negotiation, checking PHY link...
INFO : PHY - Auto-Negotiation PASSED
INFO : PHY - Checking link...
INFO : PHY - Link established
INFO : PHY - Speed = 100, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x04000203
RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 192.168.0.180
Simple Socket Server starting up
Simple Socket Server listening on port 30
Created "simple socket server" task (Prio: 4)
