13 years agoProblems with Cyclone IV and DP83848C
Dear all, I've made my own board of Cyclone IV EP4CGX110CF23C7. And i want to make a ethernet module with DP83848C which is surpported by the TSE core. However, when i have completed my SOPC syst...
13 years agoIn your signaltap project, you need to add the enet_rx_en signal (or maybe it's called enet_rx_dv). Then set a trigger to a rising edge or that new signal and see if it picks up anything. You can also regroup enet_rx[0] to enet_rx[3] so that you will directly see the hex digit.
