13 years agoProblems with Cyclone IV and DP83848C
Dear all, I've made my own board of Cyclone IV EP4CGX110CF23C7. And i want to make a ethernet module with DP83848C which is surpported by the TSE core. However, when i have completed my SOPC syst...
13 years agoThere doesn't seem to be anything wrong from the terminal output. I suggest that you use a network sniffer (such as Wireshark) on the PC you are using to connect to the board, and signaltap on the FPGA to check if anything is coming in or out on the interface with the PHY chip.
