22 years agoProblems with BusyBox
I'm trying to use busybox for my root filesystem instead of the standard filesystem. Following the Reference Guide I was able to create the busybox, the symlinks, the inittab and rcS file. I...
22 years agoHi Ken,
thanks for replying. As you suggested I tried to put the agetty.exe into bin dir, and I modified the inittab file to use it instead of the busybox getty; I tried the following command line into inittab: <div class='quotetop'>QUOTE </div> --- Quote Start --- ::respawn:/bin/agetty 115200 ttyS0[/b] --- Quote End --- but the login behavior seems to be the same,"Login incorrect". May be I'm using a wrong cmd line ... (?) The delay between the username insert and the password request seems to be a bit greater than using the standard filesystem. As for the mount question : 1) yes, I'm using the busybox mount cmd 2) the file system permissions for /dev/mtdblock1 are "brw-------" and for /usr/apps directory are "drwxr-xr-x" I built the filesystem using the NiosII IDE, but I didn't find any place there where to change files and dirs permissions. Thanks Fab
