21 years agoProblems when downloading onto EP1S10F780C6
Now, I am working on this board with Quartus 4.2 and Nios II IDE 1.1. After following the instruction from "Getting Start" document, I cannot download the "hello world" onto this board. The following...
21 years agoYou can use a ByteBlaster cable, but if you are in a noisy environment then you might have problems with nios2-terminal or the debugger disconnecting or unexpectedly reporting errors.
See the web server example, file web_server.c for an example of how to print to the LCD.
