21 years agoProblems when downloading onto EP1S10F780C6
Now, I am working on this board with Quartus 4.2 and Nios II IDE 1.1. After following the instruction from "Getting Start" document, I cannot download the "hello world" onto this board. The following...
21 years agoneo,
This is telling you that something in the system has been updated but the hardware (.sof) was not re-compiled; a common cause of this is if you open the hardware portion of the design in SOPC Builder, edit something, and then close (or re-generate).. such actions will update the time-stamp in the configuration (.ptf) file that stores information about your system. You should either turn-off the system-ID checking mechanism in the IDE (if you know that you have not made any system changes), or re-generate in SOPC Builder, and re-compile in quartus to get a new .sof.
