20 years agoProblems running web server example
Hello all! I have problems in running the web server example of my NiosII StratixII Dev Board. The project compiles and is running, DHCP fails and it uses static IP. It replys arp-requests, but...
20 years ago --- Quote Start --- originally posted by e-tricky@Dec 6 2005, 08:30 AM hello all!
i have problems in running the web server example of my niosii stratixii dev board. the project compiles and is running, dhcp fails and it uses static ip. it replys arp-requests, but i can't see the websites with my browser. are there any problems known with this demo web server?
for information: the factory design with its web server is running without problems.
thanky you!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11353)
--- quote end ---
--- Quote End --- Hi e-tricky, had the same problem here. Where I work we all have a static IP-address. What you can do best is change the time-out voor the dhcp-service. I beleive it is in dhcp.c. And change the IP-address manually to an address in your range... And that works perfectly.... Good luck, Danny
