20 years agoProblems on connecting NIOS to CS8900
Hi, Now I'm designing a NIOS Kit with CS8900 chip. I use the CS8900 interface in the SOPC Builder directly, and I'm confuse with the byteenable[1..0] pin, 'cause there isn't any...
20 years agoHello Simonhdl,
I am assuming that you have created CS8900 with its own bus in SOPC builder. If so then connect AEN to ground and connect byteenable[1] to SBHE. If you are using NIOS configured for 32bits then you would connect the address as follows; Nios Address CS8900 A2 A0 A3 A1 A4 A2 Good Luck!
