21 years agoproblems of scsi and usb :)
when i plugin my usb stick,the ide shell:
# usb 1-1: new full speed USB device using address 2 usb 1-1: decvice decriptor: bNumConfigurations=1,idVendor=422,idProduct=128,bMax PacketSize0=16,bcddevice=1,bcdusb=272,iManufacture=<4>usb 1-1: usb 1-1: control timeout on ep0in usb 1-1: control timeout on ep0in usb 1-1: control timeout on ep0in usb 1-1: control timeout on ep0in scsi0 : SCSI emulation for USB Mass Storage devices Vendor: F3D6368? Model: ?Fash Disk 1.06 Rev: !?S Type: Direct-Access ANSI SCSI revision: 02 sda : unsupported sector size 131080. SCSI device sda: 0 131080-byte hdwr sectors (0 MB) sda: assuming Write Enabled sda: assuming drive cache: write through Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0 what's the means of "sda : unsupported sector size 131080."?? i had formated usb stick as 512-byte sector in FAT32. mount -n nodev -t usbdevfs /proc/bus/usb then cat /proc/partitions , here is no sd*. why??3 Replies
How have you formattted your usb stick? I find that USB sticks typically have some weird partitioning scheme (at least to my standards). Whenever I get a USB stick, I format it with
create a single FAT32 partition on in and format it with mkfs. From that point onwards, there are no partitioning problems anymore on any OS . http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif$ sudo fdisk /dev/sda - Altera_Forum
hi, here was another error:
... /dev/scsi/host0/bus0/target0/lun0:<7>usb-storage: queuecommand called unknown partition table ... and i...... # fdisk -l /dev/ide/host0/bus0/target0/lun0: p1 Disk /dev/hda: 4 heads, 32 sectors, 246 cylinders Units = cylinders of 128 * 512 bytes Device Boot Start End Blocks Id System /dev/hda1 1 246 15743+ 83 Linux Disk /dev/sda: 3 heads, 43 sectors, 1002 cylinders Units = cylinders of 129 * 512 bytes Disk /dev/sda doesn't contain a valid partition table i know less about scsi, how??? thank u!! - Altera_Forum
--- Quote Start --- originally posted by gwbing@May 31 2005, 03:03 PM disk /dev/sda doesn't contain a valid partition table --- Quote End --- /dev/sda is your USB stick (depending on your kernel configuration and drivers, it can also be /dev/uba). But here it is not http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/tongue.gif The error you mention seems suspicioulsy to the one that makes me recreate the partition table: just
delete all the partitions and create a new one (type FAT32 or something). After you've done this,fdisk /dev/sda
Note all there remarks assume that you're doing this natively on a GNU/Linux machine. I've not used a W32 machine in years http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif I don't know what formatting the stick in Windows will do, but judging it's windows, I would assume not what you expect.mkfs.vfat /dev/sda1
