16 years agoproblems of DM9000 on DE2
i am a beginner for FPGA and i work with linux-mmu on the de2 board. https://www.alteraforum.com/forum/attachment.php?attachmentid=2777 when the system on de2 is power on,the sysinfo is...
16 years ago --- Quote Start --- Dear wang! I met the same problem as you .Have you solved it successfully? I am relly puzzled now. --- Quote End --- :) i have fix it add those lines at the bottom of setup.c #if defined(CONFIG_DM9000) # include <linux/dm9000.h> static struct resource dm9k_resource[] = { [0] = { .start = DM9000A_BASE, .end = DM9000A_BASE + 3, .flags = IORESOURCE_MEM, }, [1] = { .start = DM9000A_BASE + 4, .end = DM9000A_BASE + 4 + 3, .flags = IORESOURCE_MEM, }, [2] = { .start = DM9000A_IRQ, .end = DM9000A_IRQ, .flags = IORESOURCE_IRQ | IRQF_TRIGGER_HIGH, } }; static struct dm9000_plat_data dm9k_platdata = { .flags = DM9000_PLATF_16BITONLY, // default MAC addr .dev_addr = {01,01,01,01,01,01}, }; static struct platform_device dm9k_device = { .name = "dm9000", .id = 0, .num_resources = ARRAY_SIZE(dm9k_resource), .resource = dm9k_resource, .dev = { .platform_data = &dm9k_platdata, } }; static int __init dm9k_device_init(void) { /* customizes platform devices, or adds new ones */ platform_device_register(&dm9k_device); return 0; } arch_initcall(dm9k_device_init); # endif
