20 years agoProblems mounting CompactFlash
I'm Using the Quartus 5.1, Nios 5.1, and eCos for 5.1. I'm using the project with the CompactFlash support from the Forum. I have build the Libraries, and compiled the the fileio1....
19 years ago --- Quote Start --- originally posted by mumford@Oct 23 2006, 12:04 AM make sure you are not using the lcd and cf on the same i/o pins.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18843)
--- quote end ---
--- Quote End --- Also make sure you are using a Quartus project that enables the compact flash. I had similar problems until I realized that my project did not set up the compact flash component.
