22 years agoProblems launching Nios II ISS
Launching the Nios II ISS generates the following error message: Error! : Unable to load memory block at address 0x20 from ELF file Release/nios_program.elf Fatal Error! : Memory map is not c...
22 years agoavatar,
the iss doesn't model flash components, hence the failure to load data into it during initialisation. If you're would like to simulate flash as a block of memory instead, then you can edit the ptf file : . go the the flash module eg. Module ext_flash . edit the iss_module_name parameter value to read "altera_memory" ie. iss_model_name = "altera_memory"; The iss supports simulation of the following peripherals: . memory (ram/rom) . avalon timer . avalon jtag uart . avalon uart Accesses to unsupported peripherals will be ignored.
